It is currently Tue Jul 29, 2025 9:30 pm
 Post subject: Your Truss Rod
PostPosted: Mon Sep 15, 2008 6:00 pm
Hi Guys!
What type of truss rod do you use and where do you get them?
I would appreciate it if you can share not only type/brand but also it's size/demension.
Thanks, David
 Post subject: Re: Your Truss Rod
PostPosted: Mon Sep 15, 2008 6:39 pm
IMO Allied sells the best. It's designed by Mark Blanchard a fellow OLFer and one excellent Luthier.
PostPosted: Mon Sep 15, 2008 6:49 pm
Allied as well.
Dimensions are on their website and I think they may have a special on them at present.
Bob
Bob Connor
Geelong, Australia
PostPosted: Mon Sep 15, 2008 7:19 pm
And yet another vote for Allied's very fine truss rod.
Dimensionally it is the same as LMI's rod and they both weigh around 119 grams. This is where the similarity ends.
Allied's rod is stainless steel making it less susceptible to corrosion and uniquely threaded in such a manner that provides a gearing effect making it far easier to turn. In fact these rods can be adjusted out of the guitar with just your fingers and no wrench.
Additionally LMI's rods may have welds that protrude outside the form factor. These welds need to be filed/belt sanded flat to fit well in a 1/4" truss rod slot. With the Allied rods the welds are within the form factor saving a step.
It is superbly made and beautifully engineered - the best rod there is IMHO.
PostPosted: Mon Sep 15, 2008 7:50 pm
+4 on the Allied truss rod. I used to use LMII's 2 way Martin style, but the Allied rod is superior for all the reasons listed by Hesh. And Bob's right, they're on sale this week, $3 off .. at least through Sep. 19th. (According to their email)
Jim Womack
Will Rogers
PostPosted: Mon Sep 15, 2008 8:42 pm
+5 Allied
PostPosted: Mon Sep 15, 2008 9:28 pm
OK, I'm the odd man out here. LMI double-acting Martin-type. It adds stiffness, even when it's relaxed.
PostPosted: Tue Sep 16, 2008 9:37 am
Is this what you guys are using? one that's 14 1/2" long?
http://www.alliedlutherie.com/truss_rod ... clk=195964
One more vote for the Allied.
PostPosted: Tue Sep 16, 2008 10:09 am
True 2 way action Allied/Mark Blanchard verion part#PTR2W .250 wide x .400 deep x 14-1/4" long
PostPosted: Tue Sep 16, 2008 10:26 am
Single rod in the traditional Gibson style and I make them.
PostPosted: Tue Sep 16, 2008 10:29 am
I use the Allied rod too... The new version is vastly superior to the old. It uses & coarse thread on one end & fine thread on the other which gives much better mechanical advantage that the older left / right thread units.
Unlike Hesh, I have had to lightly file the welds on a few of the rods I've used... No big deal.
They are cheaper by the dozen & Allied will mix lengths in one order.
PostPosted: Tue Sep 16, 2008 12:45 pm
That's the one David,
I've done single action rods like Howard does on a few and like that design. It works well too.
PostPosted: Tue Sep 16, 2008 1:27 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Allied for me also!!!
I've used Stew-Macs rods also!
They are well made and work great!!
I used to make my own but the time & cost got to be a factor!
Mike Collins
PostPosted: Tue Sep 16, 2008 3:23 pm
I'll be the odd guy here as well: I use StewMac's hotrod.
Since it seems I'm the only one here using it, is there anything wrong with it? (Although I've been quite happy with it so far...)
Alain Moisan
(Now building just for fun!)
PostPosted: Tue Sep 16, 2008 3:31 pm
I like the Allied rod as well !!!!!
Mark
PostPosted: Tue Sep 16, 2008 3:35 pm
Mark
:lol:
PostPosted: Tue Sep 16, 2008 3:53 pm
Last Name: Collins
City: Argyle
State: New York
Alain;
There is nothing wrong with the Stew Mac Hot Rod!
I think the pricing is one of the reasons makers do not try them!
Also -truss rods are not a item to fool with-makers want to get the ones others have had success with!
I'm 100% happy with the Stew Mac "Hot Rods"
I really like them!!
Mike Collins
PostPosted: Tue Sep 16, 2008 6:22 pm
Ok Guys which rod in the UK, heres a link and some pics which one would you suggest
http://www.touchstonetonewoods.co.uk/ttwp10.html
or
http://www.wdmusic.co.uk/category/Hardw ... /Trussrods
or
http://www.luthierssupplies.co.uk/ though with no pics I'm not sure what is what
Formerly JJH
PostPosted: Tue Sep 16, 2008 6:51 pm
ToddStock wrote:
The new Martin dual action...Allied rod on steroids...the only double action rod I would not worry about breaking, and $11.75 per in three lengths to suit Size 5 up to long scale 14 fretters. Very powerful, stiff rod.
Interesting, Todd. Are you referring to the rod listed on Martin's 1833 site?
https://www.martinguitar.com/1833/catalog.php?cat=Kits%20Parts%20%26%20Tools&subcat=Guitar%20Parts
The price sounds nice, anyway.
Jim Womack
Will Rogers
PostPosted: Tue Sep 16, 2008 9:15 pm
Another vote for the Allied/Blanchard rod!
PostPosted: Tue Sep 16, 2008 10:06 pm
Do you Allied truss rod guys use sillicone in your truss rod slot to prevent rod buzzing? Do you use a rounded or square bit for your slot?
PostPosted: Wed Sep 17, 2008 7:17 am
Jeremy
There are installation recommendations on the Allied website.
The use of a filler strip is advised to prevent rod rattle.
It also makes the rod work more precisely.
I do not use silicone.
Mark
PostPosted: Wed Sep 17, 2008 8:57 am
What Mark said,
filler strip or spline on top, use a hardwood (only need like 1/8" max), no silicone here either.
I use a 1/4" flat bottom spiral bit to cut the channel.
PostPosted: Fri Sep 19, 2008 9:42 am
Ok so I just ordered 12 of these from Allied. I was only going to order 6 but @$12 a piece when you get dozen or more. I guess I have to build atleast 12 guitars. bliss
David
